Coolant leak in footwell?
bmw9818
Post Fri Apr 04, 2014 9:59 pm
been leaking coolant in the footwell for about 5 years figure nows about the time, whats the part i need to repair it?
http://realoem.com/bmw/partgrp.do?model ... g=64&fg=30
Taking a look on here but cant seem to find the heater valve, I can only see expensive items which I hope aint one of them...
rich318i
Post Fri Apr 04, 2014 10:20 pm
Mine was the top O-Ring, Matrix is £57 from GSF Brand is NISSIAN dont get any other like cheap £20 ones from euros, BEHR are OEM but way over priced. If it is the heater valve get a second hand one they are about £160 from BMW
Post Fri Apr 04, 2014 11:18 pm
Also check that your coolant bottle pressure cap has been changed under the 1997 recall. Still plenty that haven't and still causing leaks.
rich318i
Post Sat Apr 05, 2014 12:07 am
Mr. moore's best and most common sense advice was use talc powder and use it too see where the leak is coming from, if it wasnt in your face... TOP TIP!!!
Post Sat Apr 05, 2014 12:49 pm
i have a good heater valve here and a good matrix if needed :D
bmw9818
Post Sun Jun 01, 2014 10:46 pm
can i get away with removing the valve and replacing the o ring? or are there any other issues which causes said part to fail
