thanks
horn wiring
polsta
my horn is about the only thing thats not working, where does it connect to on the loom ? is the bit on the loom that just connects to the horn ? can anyone tell me what im looking for and to go about this please
thanks
thanks
First thing to do is to listen to relay K2 in the fusebox while someone presses the horn button with the ignition on.
Does it click?
Does it click?
polsta
thanks brian, il have a look tomorrow , im presuming so as it always worked before , but i know the actual horn isnt connected at the moment , so im hoping it just needs connecting, which is where/how please ? , and what to do if its not/cant find it there ?
Where and how depends on the spec. of your car. It will either have a single horn mounted behind the top of the kidney grill with two single spade connectors on wires connected to it, or it will have two horns, one each side, mounted BELOW the panels below the headlamps. These horns will have two pin plugs of a similar style to those connecting the headlamps, washer pump, etc.
polsta
Yes I've got the 2 under head lamp ones thanks il check for the connectors tomrrow I can't remember if I've got spare connectors there but must have, all the lights and indicators are working and still need to put the plastic panels in but il do that after the mot as the headlamps need adjusting and lining up still
Also need to fit the obc horn and air temp sensor and air ducts etc (tech 1) ,gonna try get it all done tomorrow
polsta
Another thing Brian - up by the fuse box I have 2 of the black L shaped push on connectors, (same as what go in them plugs for the lights/sensors) not very long wires , what are they for or are they spares or for something I don't have ?
polsta
Just having a look now , the horn has 2 spade type connectors at the top about an inch apart , but no spare bits on loom , only soare things are the black push/pull connectors that have the line .|. Sort of thing in the middle , with a brown/green and grey/yellow wire ?
baur320
Local garage has looked at my none-working horn and advised there is an earth fault where it connects to the steering rack.....
Does that make sense to you Brian?
Current E30 325i, E63 630is.
polsta
right i found the 2 spade connectors (1 for each horn) the relay is clicking , so just need to get them working, how do they earth ? do i connect an earth cable with a spade connector to the other socket ? then where do i earth it ?
1 of my horns, 1 of the connector spades is totaly rusted away
Horn switch eventually earths through the lower steering column, and dirt builds up on the balls insulating the column.baur320 wrote:Local garage has looked at my none-working horn and advised there is an earth fault where it connects to the steering rack.....
The test is to rotate the steering wheel while keeping the button pressed.
A good squirt of switch cleaner up the column from under the bonnet, followed by some spray grease will sort it.
Horns themselves connect to earth at a stud on the LH inner wing, below the headlamps.
polsta
ok thanks brian i know the stud, does that mean i have to run a wire right across from the RH horn ? is there no easier way nearer that horn ?
to be clear..i just need to make a wire, with a flat hoop connector on one end, and a spade connector on the other , and go from that stud to the other terminal on the horn, correct ?
What's wrong with the wire that's there already?
polsta
The only wires I have - is 1 wire to each horn from the loom with 1 spade connector in the rubber cover , which I presume is the live, no other wires, and each horn has 2 terminals- so I presume I need the wire in the negative/earth wire to each horn ?
This must be pre face lift stuff? I'm not over familiar with the finer details of their wiring, but if there's only one wire, then I presume it was intended to be used with single terminal horns that earth through their own mounting brackets.
If you have single terminal wiring and two wire horns, then a short wire from the neg. terminal to a ring terminal under the fixing nut would do the job.
