complete with reservoir and relevant pipes, be a straight swap
into a 316i touring?
I thank you.
Will a pre facelift 325i steering rack.....
gooner1
- Out humping Reindeer
the pipes are a little longer and the pump mounts differently ..the rack will fit.
+ a yard full of scrap turds
gooner1
Cheers Mick, rack is buggered on the 316i but the pump, hoses etcmagpie wrote:the pipes are a little longer and the pump mounts differently ..the rack will fit.
are fine, so maybe I can just use the 325i rack.
Only one way to find out.
That's a completely different scenario to you OP! The rack is the same, but everything else, except the reservoir bottle is different.gooner1 wrote:Cheers Mick, rack is buggered on the 316i but the pump, hoses etcmagpie wrote:the pipes are a little longer and the pump mounts differently ..the rack will fit.
Check under the rubber boots of the new rack. Any sign of fluid, then it's scrap as well.
gooner1
Thanks Brian, already checked the boots, all ok but might just fit
new ones while the rack is off.
It's not the boots themselves you need to worry about - it's what's inside them. Should be no sign of steering fluid.
gooner1
Yes I realise that, Brian, but still makes sense, to me, toBrianmoooore wrote:It's not the boots themselves you need to worry about - it's what's inside them. Should be no sign of steering fluid.
replace the boots whilst rack is off.
