Water in the boot
Mitchen
Sat Mar 22, 2014 3:28 pm
Guys, I'm getting a lot of water in the DS corner of the boot, but can't identify where it's coming from.
I'm going to get a new seal, but I can't see the water coming from the top. I put newspaper all over the carpet and in the corners and run the jet wash over it for a period of time, and didnt get any water coming in, but when I leave the car for a few days and check under the carpets, particularly on the drivers side corner, I'm seeing a puddle.
If it's was the seal, surely the the water would be coming in and weting the first aid box and everything no?
1990 320i Coupe SE
viewtopic.php?t=253048
mcspike
Sat Mar 22, 2014 8:32 pm
I had some creeping up under the seal from water gathering around there. Silicon'd it down and it's stopped it.
Ryan
ben-yatess
Sat Mar 22, 2014 11:35 pm
mine was the same and my inner arch is shot and needs repairing, could be the same
Mitchen
Sun Mar 23, 2014 2:56 pm
Cheers boys.. I've tried the talc idea, so let's see if it gets me anywhere, I'm due rain tonight as well.
New seal is being ordered!
1990 320i Coupe SE
Jona1971
Wed Apr 23, 2014 8:47 pm
Any news? I've got the same problem.
etouring
Wed Apr 23, 2014 10:32 pm
Iv got a touring and same thing, water fills the n/s where the tools are kept. Everyone says it's the taillight seals. I just drilled a small hole and let is drain
Mitchen
Wed Apr 23, 2014 11:42 pm
I fitted a new boot seal but didnt cure the problem, and still can't seem to see where it was coming from, even using talc and newspaper. In the end I've put a towel in that corner and left it, seems to absorb whatever comes in.
One day once I've sorted everything else, I'll spend some time look at rear light seals etc.,
1990 320i Coupe SE
JF008
Thu Apr 24, 2014 12:18 am
there are vents on both side of the car behind the rear bumpers, you can see them if you remove the boot lining. You can easily replace the seals on those by taking the bumper off and also tail light seals are to check.
DanTheMannn
Sun Apr 27, 2014 2:09 pm
Mine i had to remove tail lights, they're was a nice hole behind the o/s tail light!
Check there :)
woerie938
Sun Apr 27, 2014 10:22 pm
I also have had problems with water in the boot. I had several leaks.
* I have an original spoiler (that rubber thing) And that's bolted on. 1 bolt was missing.
* When I removed the rubber of the trunk, There was an little hole due to corrosion.
* And water came in at one bolt of the bumper.
