2.7 help
Laith
Post Wed Mar 19, 2014 4:43 pm
321354324262 - that's an ebay id of an engine I want to buy.
Got a few Qs id like to ask you lads:
1) how much should I offer?
2) he says it's a stock 2.7 stroker and it has 2.7 stamped on the head. Is this true?
3) he's had the car 3 years and is breaking it due to a crash..
E30_Aza
Post Wed Mar 19, 2014 4:52 pm
Not exactly a great add is it. No description of the build etc. 2.5 heads have 2.5 & 2.7 stamped on them so don't assume it's a 2.7 by that. You need to find out the build spec on it before you offer a price I think
Kedge
Post Wed Mar 19, 2014 4:56 pm
99.99999999% sure that's just going to be a standard 2.5 M20. As Aza says, 2.5 heads all have 2.5 & 2.7 stamped on them.
Instagram - Kedge85
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Mar 19, 2014 5:13 pm
Doesn't matter what's on the head; find out what's on the block (machined flat surface just above the sump, under the starter motor).
There's no such thing as a "2.7 sport motor", so the seller has no clue what he's got.
**BANNED**
Post Wed Mar 19, 2014 6:45 pm
Doesn't matter what's on the head,doesn't matter what's on the block,as long as it has an 84mm bore and an 84mm stroke....
The best 2.7's have used a bored out 2 litre block,so what is stamped on the thing is almost meaningless.
Youth is wasted on the young.
Post Wed Mar 19, 2014 7:24 pm
daimlerman wrote:Doesn't matter what's on the head,doesn't matter what's on the block,as long as it has an 84mm bore and an 84mm stroke....
True, but an engine number starting with 27 would at least indicate that it probably is a 2.7.
ZARS
Post Fri Mar 21, 2014 2:10 pm
I've sent the seller an e-mail too but he hasn't got back to me as yet. Thought this could be a quick swap to my 320 which is way too slow.
BMW E30 320i coupe
Porsche 951
Merc W203 C180K
Saab 9-5 SE
