I managed to find a local motor factors, picked up come coolant and and a pair of new Gates belts, fitted them up, all ok.
I got another 20 or so laps in before it threw the PAS belt of again. I called it a day at this stage as I had a 170 mile home journey and I could live without PAS but not without a water pump! After this it made the home journey without any problems apart from tired arms (M30 + no PAS + Z3 quickrack = hard work!).The belts were correctly fitted and tensioned, so what's causing it? I've not lost one before in 8+ years of M30 ownership.
Suspected causes...
Water pump: - slight play, about 0.5mm at the lip of the pulley, this is only a couple of years old. Spins freely with no bearing noise.
PAS pump: - old, unknown age. No detectable play, also spins freely.
Alternator: - again old but no sign of problems here.
Bottom pulley - these are massive things on the M30 and I believe rubber isolated. I didn't try prying it about as if it's on the way out, breaking it completely would not be a good plan when many miles from home. There was no play to be felt by hand though.
When running all pulleys spin without any visible wobbling or misalignment.
All suggestions welcomed, silly or otherwise!
