Which rad to use for a chromie with facelift engine 2.5
MOODY
Hi there all bit of a sticky one but here goes I'm converting my chromie to 2.5 m20 from a 1.6 but want the engine be clean and tidy don't really want any bottles on sides, so wanted use a different radiator with collany bottle attached if possible, which rad is best to use for this look?
appletree
The standard 325 one uses a remote header tank doesn't it?
sweep
yes
E30 318iS uses the same radiator as an E36 325, so go for that one, including mounting hardware.
MOODY
So Brian will the 318is rad give me no problems, I.e clear viscous etc and what pipes will I need use?Brianmoooore wrote:E30 318iS uses the same radiator as an E36 325, so go for that one, including mounting hardware.
appletree
Sorry mis understood your first post, thought you ment that you didn't want a tank on the side of your radiator.
Yes a M42 one will do the job.
