Strange whine from rear
sh55123
Thu Feb 13, 2014 8:20 pm
Hi,
My 325i Sport has recently developed a very strange rear end whine - rather than trying to describe it, I have found a youtube video of a car with exactly the same noise..
Does anybody have any ideas? I am sure it is coincidental, but this noise started after removing my propshaft to replace the guibo and centre bearing. Initially, I thought it was a bad center bearing, so replaced it with another from a different manufacturer, and it still makes exactly the same noise.
Any help greatly appreciated!
'87 325i cabriolet, manual, Zinnobar Red
'91 325i se coupe, manual, Laguna Green
Thu Feb 13, 2014 8:49 pm
Diff. input bearing is the most common source of a whine on an E30, but it's impossible to tell from a recording coming from a laptop's speakers.
sh55123
Thu Feb 13, 2014 10:06 pm
Hi Brian,
Thanks for the reply. I have three 325i's, and one pf them has what I would describe as a bit of a whiney diff (whines a bit arouund 50-60 mph). The noise coming from the car in question only happens for the first few miles when cold and is very loud. When warm, it and then disappears completely. It is a strange whine (as in the video) that seems to wind up, pause, and then wind up again, even when staying in a single gear. I thought it sounded quite distinctive in the video, and as soon as I stumbled across the video on youtube, I instantly recognised it as being identical to the noise my car is making.
If it were the diff input bearing, would pre-loading the prop centre bearing place more strain/pressure on the diff input bearing and cause it to whine more? Maybe the propshaft centre bearing was not properly pre-loaded before I started working on it?
Thanks again,
Steve
