HID vs LED Cree for elipsoid head lamp
markus_74
Sun Feb 09, 2014 5:41 pm
hello,
I want to up grade my head lamp, which is better and brighter for elipsoid headlamp?
I got problem if driving in the rain cause the light can pass the rain.
thank you
Fred555
Tue Feb 11, 2014 4:00 pm
Which Cree LED has a high enough light output? Do you want to replace the Halogen main headlamp bulb or the parking light bulb? Post a link to the Cree LED you mean.
All you need to fix anything is grim determination – that and belief.
pianist
Tue Feb 11, 2014 5:30 pm
LED's suitable for car headlights cost over £150 and they are about 25w in power if you thinking about eBay stuff I think you will find that they are not suitable for the road use simply because they are just like candle light compared to halogen bulbs where HID's are even brighter than halogens. If you don't trust me then try It for your self :wink:
Tue Feb 11, 2014 8:22 pm
LED technology advances noticeably by the month, ( I fit lots of the things as part of my work), but it's still a long way from a single bulb to replace a conventional headlamp bulb. AFAIK, all the OE LED headlamps in use at the moment use multiple lamps.
markus_74
Tue Feb 18, 2014 6:20 am
2x H1 10W 10SMD Car LED Bulbs White Headlight Fog Light Driving Lights Lamp NeweBay item number:141131890396
and
2x H1 10W High Power SMD LED COB Bulb Fog Driving Lamp DRL Light White New
eBay item number:131051993379
2x H1 50W CREE + SAMSUNG High Power LED Xenon White Fog Light Daytime Running
eBay item number:321199445880
Tue Feb 18, 2014 9:57 am
10W LED just isn't enough with current technology, and they all use multiple light sources which will play havoc with the beam pattern.
Give it another five years.
Tue Feb 18, 2014 10:20 am
Its why they describe them as "daytime lights/fog lights"
The output is not good enough to light the road ahead
I have a 20w single LED security light in my back garden and while its very bright (as much as a 100w standard floodlight) it doesnt project the light half as far, ok close up but dims over about 20ft
Dave_M3
Thu Feb 20, 2014 10:17 pm
LED headlamps to match the performance of HIDs are about 250-500 quid!
I've HIDs in mine in all fogs, low and high beams and find them brilliant. Even the low beam units alone are well worth it.
They're getting strict here now though with only allowing cars with OEM HIDs and must have leveling, headlight washer jets and projector lights.
Reckon I'll try get away with hiding my ballasts well and fitting washer jets and maybe electric level adjusters
For my Defender, I'm using these;
http://www.truck-lite.com/webapp/wcs/st ... &langId=-1
Same stuff that they use in the US military in the Humvees.
