I need to remove the steering wheel from my 318is - it is the type with the horn buttons on the spokes (Mtech 1?) Does anyone now how I gain access to the retaining nut? I guess something pops off but is it just the centre or what?
Robin
Removing the sterring wheel on a 318is
martinclan
It's an E30 Jim but not as we know it...
ste00
center bmw badge comes off then theirs a large nut behind,
mrLEE30
take a little flat screwdriver and prise out the BMW logo.
optional to put on the steering lock, never done it myself I just hold the wheel when you loosen the nut.
undo the nut half way,
pull till loose,
take off steering lock
undo the nut all the way
pull off (the steering wheel!)
look for the washer you have dropped on the floor.
dont forget to mark a piece of tape on yer wheel and have it at the top, dont turn the splines when the wheel us off, replace steering wheel with tape in same position so wheel will still be straight.
easy peesy
mrlee
pull till loose,
easy peesy
mrlee
Optional to put steering lock on to undo nut, but essential to have lock released to pull off the wheel.
Nut is 22mm.
Nut is 22mm.
martinclan
OK - thanks guys - that's just what I needed to know - the nut's under the logo... (must be a joke there somewhere)
Robin
Robin
