New to the forum, trying to get a few jobs sorted.
Rear demister not working, where is the fuse located so ican check?
Thanks in advance.
Rear demister
zd3bx
Fusebox is a blue box in the engine bay on the passenger side.
Fuse no 8 should be 30amp.
Here's a diagram > http://www.e30zone.net/e30zonewiki/index.php/Fuse_Box
You'll be lucky if it's just a fuse, rather than a burnt out grid, which will mean replacing the screen - still pretty easy and cheap, as it's not glued on, but more hassle
Cloggy Saint
L9XSS
Thanks for the fast replies, very much appreciated!
