I am trying to install senders for oil pressure and temp according to the Wiki help page on installing VDO guages it says that on the M40 there is a blank on oil filter housing that could be used for one of these senders. Having looked for this blank the only one I can see is in front of oil filter housing just underneath the alternator belt.
Can someone please confirm if this is the blank that can be used for the sender if not can some point out exactly where this blank is located.
