Grinding / Rubbing when turning left?
Altrezia
Post Fri Jan 17, 2014 4:52 pm
Hey chaps. My car does rub the arches with the tyres over bumps - but worse than that, I get a loud rubbing / grinding noise which doesn't really sound like tyre-on-metal when I turn left.
Any ideas what I should be checking? Just had an MOT and no advisories on wheel bearings, but I will still check them anyways.
Ta!
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Jan 17, 2014 5:04 pm
Sure it's not something simple, like the plastic arch liner come loose?
pac1982
Post Fri Jan 17, 2014 5:44 pm
Grrrmachine wrote:Sure it's not something simple, like the plastic arch liner come loose?
+1
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Altrezia
Post Fri Jan 17, 2014 5:56 pm
I don't have arch liners. I'll get it up on the jacks tomorrow and have a poke around. It's weird - doesn't sound like a tyre, doesn't really sound like a whir-whir-whir-wheel bearing either - a bit smoother.
jmc330i
Post Fri Jan 17, 2014 6:16 pm
Brake disc back plate rubbing the disc is another simple check and fix.
James
'91 325i Sport
'93 318i touring 16v
Altrezia
Post Fri Jan 17, 2014 6:39 pm
I don't have back-plates either. Ha ha.
jmc330i
Post Fri Jan 17, 2014 6:57 pm
Altrezia wrote:I don't have back-plates either. Ha ha.
:roll: lol
From your other thread, you've just changed the brakes - did it make the noise before you changed them?
James
'91 325i Sport
Altrezia
Post Fri Jan 17, 2014 7:13 pm
I never drove the car before I changed the front discs&pads - but I'd say it's the rear end of the car if I had to guess.
The rear brakes are just drums, and it has just had two new rear cylinders - but it did make the noise on the way to the garage for that work, too.
G-Bear
Post Fri Jan 17, 2014 10:59 pm
Manifold on the steering linkage? Check to see how tired your engine mounts are, in particular the o/s one. Have you got an E30 steering rack? I know its a problem on newer model racks but at a guess if your engine mounts are sh@gged enough perhaps that might be your problem.
Altrezia
Post Fri Jan 17, 2014 11:01 pm
They don't seem that bad - but I suppose they could be borked. Will check them out
mcbonio
Post Sun Jan 19, 2014 8:56 pm
Sounds like a bad wheel bearing to me.
Failed wheel bearings can be overlooked by MOT testers, as they only look for vertical play on the wheel. I've had 2 failed bearings on mine which only made a grinding sound when turning due to the weight transfer on the opposite wheel. That extra weight made the bad bearing grind.
