e30 brake pressure regulator
aceifty
Does anyone know where the e30 brake pressure regulatorg is on a 325i cab
1989 cab M20B28 build
Grrrmachine
- E30 Zone Wiki / Team Member
Is there one? I don't think there's anything in the plumbing between the master cylinder and the calipers, other than a simple brass T-piece by the fuel tank.
aceifty
if there isn't one then what is the thing that is just above the chassis leg on the passenger side, just below the master cylinder. only asking as i have fluid leak from there (what ever that thing is)Grrrmachine wrote:Is there one? I don't think there's anything in the plumbing between the master cylinder and the calipers, other than a simple brass T-piece by the fuel tank.
aceifty
the car does have rear factory brake discs, but non abs
Grrrmachine
Hmmm, according to RealOEM there is such a thing, but I don't remember seeing one on my touring. Seems like you've answered your own question.
As for the leak, are you sure it is that thing, not the master cylinder leaking down the brake pipe?
Pressure regulator is on the bulkhead in the engine bay, just a few inches from the brake master cylinder.
aceifty
iv checked all the pipes and the mastet cylinder and they are dry, the only thing that is wet is the thing below the master cylinderGrrrmachine wrote:Hmmm, according to RealOEM there is such a thing, but I don't remember seeing one on my touring. Seems like you've answered your own question.
aceifty wrote:iv checked all the pipes and the mastet cylinder and they are dry, the only thing that is wet is the thing below the master cylinderGrrrmachine wrote:Hmmm, according to RealOEM there is such a thing, but I don't remember seeing one on my touring. Seems like you've answered your own question.
Brianmoooore wrote:Pressure regulator is on the bulkhead in the engine bay, just a few inches from the brake master cylinder.
aceifty
Can i just replace the seal on it or will i need to replace the whole thing
BMW don't list any individual parts for it, But I expect it's just a copper or alloy washer that you should be able to get from a motor factors. May just need tightening up.
aceifty
Ill try tightening it up and see if that stops it, if not then ill remove the whole thing and take it from there
Its an O ring, see here - http://www.e30zone.net/modules.php?name ... lit+system
aceifty
thanks for that.DanThe wrote:Its an O ring, see here - http://www.e30zone.net/modules.php?name ... lit+system
Know i need to check if i have a straight through piece or a pressure regulator
aceifty
Got it sorted, just was a bit loose
