e30 h26 hartge starting issues
beemer1664
Post Wed Jan 08, 2014 8:14 pm
Hi guys, if I leave her for about 2 or more days I have to crank her over for about 30 seconds before she starts, once warm shes starts on the button, I only got her 3 weeks ago, so plugs, oil , air , ect will be changed asap!
Do you think this would solve problem?
cheers :D
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Jan 08, 2014 8:20 pm
I'd expect a leak on the fuel side so that you're losing fuel pressure. Pull the injectors and send them off to Injectortune for a rebuild, but also check the condition of all rubber fuel lines in the engine.
If it's still bad, do a TEST on the blue coolant sensor (DO NOT REPLACE IT WITHOUT TESTING!).
beemer1664
Post Thu Jan 09, 2014 8:39 am
Cheers mate, will take a look
