PAS Pipe - M52B28 and E36 M3 rack conversion
J90rdn
Post Wed Jan 08, 2014 12:25 pm
Hi - hoping someone can help.
Currently converting from pov spec 316 to M52B28, and at the same time converting from manual rack to E36 M3 PAS. While the engine bay is empty thought it was a good opportunity to put the rack and pipework in. I managed to get my hands on an E30 325i PAS rack and pipework (including reservoir) in the hope the pipework would fit, but it seems the pipe from the pump to the rack is different (needs the larger bango at the pump end).
I know Danthe sells conversion pipes, but I can't stretch that far atm. Could I simply get hold of an E36 pipe and adapt, seeing as the rack end and pump end are both from an E36?
