hello, zoners
can I just tracking it with regular type or use m3 spec for tracking?
thank you
markus
how to tracking with eccentric bush?
markus_74
Grrrmachine
- E30 Zone Wiki / Team Member
Tracking has nothing to do with bushes; it's set with the steering tie rods. To set tracking you modify the "toe" angle.
http://www.e30zone.net/e30zonewiki/inde ... d#Geometry
TheDutch
I imagine the intended question is whether to set the toe according to standard specification or M3 specification if you are using the M3 offset bushes.
pac1982
I would also be interested in knowing the answer to thatTheDutch wrote:I imagine the intended question is whether to set the toe according to standard specification or M3 specification if you are using the M3 offset bushes.
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
One is 17' +/- 5' and the other is 18' +/- 5', so I don't think it'll make any practical difference.
https://www.bmwtechinfo.com/repair/main/941en/index.htm
capnmchl
According to the 1994 Autodata book I looked in for mine, the toe is the same for all E30's except the iX. 2mm toe in, + or - 1.
