Low fuel light not working
Cloggy Saint
PG325
My low fuel light doesn't come on until the needle is almost under the red section!
Have you run it down really low?
I suppose it could be the fuel sender not sending a signal.
Cloggy Saint
Comes on when the needle reaches the bit that actually lights up, not the red painted section.
Only known them fail if the gauge has failed as well - usually as a result of someone trying to remove the fuel pump without removing the sender first.
