Cleaning Injectors
dbell
Post Mon Dec 30, 2013 9:10 pm
Hi all, i was thinking of giving the injectors in my e30 sport a bit of flushing out, my thinking is after 24 years it might be slightly beneficial. I am sure some members have done it in the past, and any comments would be appreciated, either good or bad.
Thanks in advance.
David.
scallyally
Post Mon Dec 30, 2013 9:58 pm
"Injector tune" is your man, be sure to mention the zone for a discount. Quick turnaround and a before and after flowchart. ( about £10 per injector)
Post Mon Dec 30, 2013 10:17 pm
As above - not a DIY job. You may be able to clean them to some degree, but you won't be able to balance and calibrate them.
After 24 years, it will give you the best bhp/mpg per £ return that you are ever likely to invest in your car.
dbell
Post Tue Dec 31, 2013 11:44 am
Thanks to all for the sound advice.
David.
