Heater slider control stuck
Laith
Post Sun Dec 22, 2013 7:42 pm
Weird problem just cropped out of nowhere..
My middle slider that controls air flow to vents facing the driver/passenger wouldn't go far left, so I forced it a bit and it clicked into place and now won't go back right at all
What can I do?
sweep
Post Sun Dec 22, 2013 7:43 pm
stereo wires behind caught it?
Laith
Post Sun Dec 22, 2013 8:01 pm
Radio seems to be working fine though. Will double check.
Laith
Post Sun Dec 22, 2013 9:05 pm
Yes you were right. Sorted :)
Post Sun Dec 22, 2013 9:10 pm
sweep wrote:stereo wires behind caught it?
That's the usual. Now that you've forced it, it might you simply broken, or the cable outer may have moved under its retaining clip.
Pulling off the knobs, the escutcheon behind them, and undoing the four screws that you've just exposed will get the slider plate loose, and taking off the panel above the driver's legs will allow you to get a view of the other end of the cables.
