rear brake upgrade from drum to disc?
markus_74
Post Thu Dec 19, 2013 3:22 am
hello, Friend
I want to up grade my old drum brake to disc, does it will improve a lot?
or if it is only a little improvement i will stay with old drum brake.
any zoner here has info?
thank you
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Dec 19, 2013 5:34 am
Rear brakes do very little of the overall braking. The real reason for replacing drums with discs is that maintenance is easier. Replacing discs and pads is a lot quicker than replacing drums and shoes.
markus_74
Post Thu Dec 19, 2013 7:42 am
Thank you grrrmachine
milescook
Post Thu Dec 19, 2013 2:51 pm
That might be overstating a touch though surely Grr? Obviously a lot of tourings have disc brakes to cope with the extra weight, and sportier versions have to shed off more speed...? :mad:
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
Grrrmachine
Post Thu Dec 19, 2013 6:23 pm
The braking balance is still very unevenly split, and Markus has a 318i saloon, not a Touring.
Remember, it's not about braking force but heat dissipation; drums can easy generate the same braking force as discs, they just hit their brake-fade point quicker, which is why the heavier/sportier models have discs.
milescook
Post Thu Dec 19, 2013 7:02 pm
Fairy nuff! :D
**BANNED**
Post Fri Dec 20, 2013 8:42 am
I ran a 316i touring alongside a 320i more door for several years,both had the same front pads and braking performance was the same for both cars,the touring,perhaps,had slightly more 'bite' when the brakes were used gently.
Youth is wasted on the young.
