jsut bought some HnR springs for my IS
dont wona ruin my pirelli tyres and was wondering, what bushes do i need to buy to get the camber corrected?
obviosuly the tracking will need to be reset also i presume?
35mm drop query
Dan318-is
my car was on this and all i did was the tracking. The camber on the front didn't wear my tyres out and the rear was no worse than on M-tech springs
TBH i think it will be fine. But if ure really bothered fit some eccentric trailing arms bushes which are Ԛ£25 per side plus fitting if u don't do it your self.
I'd drop it and see how it goes or just fit one pair of the bushes, 1 on each side. But i can't remember whether it's the inside or outside bush to replace.
HTH
and i have a pair of eccentric bushes at home, depending on if u would want them!
HTH
liam012
i dropped 35mm with h+r kit and again just did tracking - not a bother and very even wear on the tyres. runnning 205/50/16s
Dan318-is
liam im also running 16s
cheers si, how much?!
