Clutch cylinders
Andy325i
Tue Nov 26, 2013 9:26 pm
I'm thinking the clutch master cylinder is starting to show its age on my 325, if I hold the clutch for more that a few seconds (like parking in tight gaps etc) it starts to bite very near the bottom (normal place for mine is about 1/4 off the floor)
To me this feels like M/C seals, but what symptoms would the slave cylinder failing give? Presumably not wanting to go into gear at all?
Advice before I order would be much appreciated :D
Many thanks
Andy
jimbom30cab
Tech 1 freak
Tue Nov 26, 2013 9:31 pm
Andy, i've got a spare slave cylinder you could fit and see if it makes any difference. Its brand new and a 2 nut job if i recall correctly.
Tue Nov 26, 2013 11:24 pm
Slave cylinder leaking would give exactly the same effect, but you would be losing fluid as well.
Not losing fluid = master cylinder faulty.
Losing fluid = either faulty - the mess will show you which.
Either way, it's recommended that both are changed at the same time.
Andy325i
Wed Nov 27, 2013 9:19 am
Thanks guys :-) Jim what make is it and how much? :-)
