indicators not working.
makman
My hazards and indicators have failed to work! Hazars switch just stays illuminated and nothing at all from the indicators. Enyone got eny advise? 3pin relay? Switch?
Canny Beat a chromie!'
Hazard switch itself is first port of call, especially if it hasn't been used in a decade or so. Easy to strip down and clean.
As a quick check, link together the green/purple and red/white of the switches socket with a short piece of wire. This should make the indicators work on the stalk, even with the ignition off.
makman
Diamond mate thanks.
