Heated mirrors.... L & R the same???
miniblob
Post Wed Nov 13, 2013 12:14 pm
Next up from me... I'm sure I've read online that you can have heated mirrors on an E30???
If so, is it just a case of looking out on here/ebay for the correct mirrors, or is there a simple mod/different glass that can be fitted???
Also, wondering the same thing about heated washer jets - although I doubt i'd bother fitting those!!!
327 Touring with bass!!!
Post Wed Nov 13, 2013 12:25 pm
Two wires, a live and an earth tapped into the original elec mirror wiring, spade terminal on the end of each wire and then its just a case of plugging them onto a heated mirror glass
miniblob
Post Wed Nov 13, 2013 1:01 pm
Sounds nice and easy!!!
Heated mirror glass £8 upwards on egay!!
A couple of silly questions then - does the mirror glass just clip in??? Will the old one just un-clip/pull out with a little force/leverage???
And any idea which two wires to use???
Post Wed Nov 13, 2013 1:10 pm
Youtube will show you how to remove the glass I expect, get a test light if you cant find a wiring diagram, easy job! :D
miniblob
Post Wed Nov 13, 2013 1:39 pm
Found it in the wiki :o:
http://www.e30zone.net/e30zonewiki/inde ... rror_Glass
Nice one matey, cheers!!!
Post Wed Nov 13, 2013 2:07 pm
Wires required are the black and the brown.
miniblob
Post Wed Nov 13, 2013 2:12 pm
Perfect - thanks Brian!!!
miniblob
Post Thu Nov 28, 2013 4:21 pm
I'm assuming it doesn't matter which way round I connect the black & brown wires???
Brown +ve???
I assume there won't be a voltage to either unless it's cold enough to activate the heated mirrors???
Post Thu Nov 28, 2013 7:19 pm
Either way round, they are on with ignition
Post Thu Nov 28, 2013 7:21 pm
Black = 12 volts +, brown = 0 volts (earth), but doesn't matter which way around they are connected to the mirror element.
No control whatsoever - the mirrors are heated all the time the ignition is on (first position, onwards).
miniblob
Post Fri Nov 29, 2013 1:52 am
Didn't realise they were on the whole time - thanks again guys!!!
Just a shame the mirrors I bought off egay are not the correct fitment - even though the auction promised a 'proper replacement with fitted clip just like original'!!!
I'll name & shame if the seller doesn't sort it!!!
Post Fri Nov 29, 2013 10:25 am
I have correct E30 heated mirror glasses and looms if needed . Not for £8 though.
Post Fri Nov 29, 2013 12:07 pm
Any council blue tint E39 heated glass Pete? Mine are fooked on the pleb wagon
Post Fri Nov 29, 2013 12:25 pm
DanThe wrote:Any council blue tint E39 heated glass Pete? Mine are fooked on the pleb wagon
Too 'new' for me Dan ! I will keep my eyes peeled , its the Ace Monday ! :)
miniblob
Post Fri Nov 29, 2013 4:11 pm
I'll bear you in mind Pete!!!
Euro's have the left heated glass for £10.56, but the right hand glass is cheaper and not heated!!!!
Are the left and right mirror glass' not the same??? Is there a left & right???
miniblob
Post Sat Nov 30, 2013 11:35 am
Very tempted to order two heated left's and see if one fit's the drivers mirror - somebody stop me before I make another errored purchase!!!
As usual, euro's have them available with free delivery, but not in either of my local branches, so I can't even go and have a look!!!
gromgsxr
Post Sat Nov 30, 2013 11:44 am
where i work it in our mirror supplier book it says L+R are same part no but only lists a standard mirror so not sure if the heated would be diff.
miniblob
Post Sat Nov 30, 2013 11:49 am
That's good enough for me - why else would they only stock a left heated and only a right non-heated???
I would order them now..... but euro's website is now down!!!
Wonder if I'll get the right part this time - they normally manage to send me the wrong parts!!!
gromgsxr
Post Sat Nov 30, 2013 11:52 am
well that means they are the exact same shape my supplier only lists the stick over glass so im wondering if the backing plate are diff for l/r though
miniblob
Post Tue Dec 10, 2013 12:34 pm
Ok, so just to confirm for anyone else thinking of bothering with this - Euro's definately DO NOT sell heated mirror glass for E30's!!!!!!!!!!!
You can see it on the website, you can order it (at a slightly higher price than non-heated), but you will only ever get non-heated glass!!!
Another order ECP have messed up on, another morning I had taken time out to fit them, wasted!!!
Where are you Pacer???? Prices please on your oem parts???????????
markus_74
Post Wed Dec 18, 2013 3:26 pm
hello, sorry for hijacked your thread
I really want to know, how the bad effect if the heater on all the time? does the mirror will be fade? or ... I live in tropical hot weather but I need it when rain.
thank you
