Diff output shafts - they move in and out very easy
jimbom30cab
Tech 1 freak
Post Tue Nov 12, 2013 9:34 pm
On one side the output shaft moves out very easily from the diff
So much so, that with the rear end on axle stands the weight of the half shaft and hub pull the diff output shaft out slightly
Is this ok ?
or is my "shaft seal with locking ring" fu*ked ? item 3 on this link. ?
http://www.realoem.com/bmw/showparts.do ... g=33&fg=10
gromgsxr
Post Wed Nov 13, 2013 12:32 am
dont sound to smart to me
b12rlw
Post Wed Nov 13, 2013 12:59 am
Part 3 is more likely to be missing, I'd have thought. have a peek inside the diff once part 1 is removed.
