e30 heater and windows?
danny314
Sat Nov 02, 2013 6:40 pm
Hiya chaps ive had a e30 sport parked for around 6 months brought it and never touched it had a good look at it today the heater when on making a loud noise and its not working what most likely would be at fault also the windows both stopped working since i brought it i looked at the fuses changed them all the switches ive changed the sunroof works but windows nothing would that most likely be the motors on both windows? thanks if anyone could help
Sat Nov 02, 2013 6:48 pm
When you say " the heater is not working", do you mean the fan or the heater?
Sunroof and windows share the same power supply, so if one works, so should the other. Check that the thermal cutout (the "switch" in front of the RH window switch) is fully pushed down, and if it is, pull it out and check that one of the wires hasn't fallen off of it. The sockets that push onto the switch is a little under specified.
Do the switches light up with the ignition on or doors open?
danny314
Sat Nov 02, 2013 7:00 pm
nope well the heaters are working but its making a bad noise and il check torrow the wires as u suggested mate what would u suggest i should replace on the heater and cost ?
Sat Nov 02, 2013 7:06 pm
Probably the fan bearings are crying "enough" after 25+ years of no lubrication. If caught in time, the plain bearings will respond to a clean up and some light oil, but if they've worn, then a replacement motor and fan assembly is needed.
Easily accessed through the large removable panel in the bulkhead at the rear of the engine bay.
danny314
Sat Nov 02, 2013 7:22 pm
cheers brian :D
