Scorpion fitment!
oguz327
Captain Armco
Captain Armco
Post Tue Dec 20, 2005 8:46 pm
Finnaly got my scorpion center section and back box fitted to my sport 1 today by a friend of a friend who works in a mazda garage.
Thing is he fitted in his lunch break and allthough he did a good job (i watched him do it) he didnt have time to play about with it to get the tail pipes central.
the car is going into my mates garage in jan or feb to have some other work done and hopefully sort this out while hes doing the other bits.
is this normal for scorpions not to fit too well?, has anyone else had these problems?
i was told that they were a good fit normaly.
if its a simple job to alighn correctly i may have a go myself!
would welcome any advise!
Simon
Post Tue Dec 20, 2005 9:09 pm
Best way to get a good fit with regards to the box at the back, loosen all the mounts/brackets from where the centre meets the downpipe, position the back box where you're happy, hold it there when someone re-tightens everything back up, when your fitting the system on your own, getting it to sit properly where it exits the valcence can be difficult!
oguz327
Captain Armco
Captain Armco
Post Thu Dec 22, 2005 11:46 pm
cheers bud, gonna have a go tomorow with a friend to help!
Steviec
Post Fri Dec 23, 2005 8:36 am
It is a bit of a job to get it to line up, it really needs 2-3 people. One to hold the box straight, one to tighten everything up while your holding it straight and someone to look from a distance to get a better idea if it is straight.
keith52
Post Fri Dec 23, 2005 6:38 pm
Too true, i'm so pxxxed off with mine ,i can't get it straight coming out of the rear valance and it's so heavy , maybe after xmas a replacement system will be ordered. Watch this space for a fairly new scopion rear box for sale
A1BMW325iSport
Post Fri Dec 23, 2005 10:47 pm
my dad helped fit my scorpion system, it fitted like a glove but as mentioned above you do need someone to help you really whilst you tighten it all up
charlE30
Post Sat Dec 24, 2005 8:02 am
I fitted a complete scorpion yesterday, didn't have access to a lift and managed to get it central. Car was on axle stands and ramps so was lying on my back, bloody hard work on your own but achievable. Good luck
BMW F31 335d xdrive
telski789
Post Sat Dec 24, 2005 12:29 pm
mine went on a treat,no complaints,have you used two straps on the rear box? if not you should,stiffens it up and you can tighten them whilst its in position and itll never move
Tel
A1BMW325iSport
Post Sat Dec 24, 2005 4:22 pm
yes i used the 2 straps that scorpion gave me
