I took the prop off because there was this awful rattling noise from underneath and I quickly found out it was this - see arrow below. Its just rattles around the shaft.
So then I noticed when looking at the bearing its self, it looks a bit off set, have a look below and see if you agree or not.
I think the whole inner bearing has moved towards the UJ joint by about 8 or 10mm
I think i'll pop the shaft down a local garage I know and see if they think its moved and if they can position it correctly.
But I wonder why this has happened ?
Any help is most appreciated
