Hi all,
As you'll all have noticed, we've had a bit of a downpour over the last 3 days. This led to me noticing a damp smell within my boot, and on further inspection this evening I found that the passenger side of the parcel shelf is wet! It's only wet at the base, the interior cabin aspect is totally dry.
Never noticed this before, it's a new problem. Not entirely sure where this water is coming from but I have two initial thoughts:
1. Rear windscreen seals?
2. Rear pillar drains?
Any help would be much appreciated. [Pacer]Pete, please impart some wisdom!
Ajay
Wet parcel shelf!!
Motorhole
Could also be water elsewhere in the car causing condensation on the glass, which runs down the screen onto the parcel shelf.
rich318i
thats not a good sign check the drain run it might of rusted though.
