Can't install Front strut bar
markus_74
- Contact:
Hello,
need info, what is wrong when my new front strut bar did not fit into my front strut suspension screw?
does my car front strut brace has a deformation?
how to fix it?
and can I use adjustable front strut bar to fix it?
and does fitting front strut bar is worthed?
thank you
markus
how to fix it?
thank you
markus
milescook
- Contact:
Hi there post up some pictures and I'm sure the guys will try and help you out.
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
march109
- Contact:
Try jacking up one side of the vehicle. Sometimes they don't quite reach and jacking one side up will bring the strut tops closer together so the strut bar does reach. At least I think that's your issue!!
pac1982
front struts are only really worth fitting if you drive hard, it may not fit due to you having the wrong version, I'm fairly sure they differ for 6 pot and 4 pot cars and you could have even been sold one for a totally different car
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
- Kos
- Contact:
Or the car is bent........
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
markus_74
- Contact:
yes this is my issuemarch109 wrote:Try jacking up one side of the vehicle. Sometimes they don't quite reach and jacking one side up will bring the strut tops closer together so the strut bar does reach. At least I think that's your issue!!
which point should I jacking up? at the tire or the body?
the different is about 1 centimeters from original strut bar holes.
does is it a big gap or normally because of the car age?
markus_74
- Contact:
but I hope with strut bar I can make my chamber of my car become back to original condition, because strut bar is corrected it?pac1982 wrote:front struts are only really worth fitting if you drive hard, it may not fit due to you having the wrong version, I'm fairly sure they differ for 6 pot and 4 pot cars and you could have even been sold one for a totally different car
and make the car handling better?
is it correct?
i had an issue getting mine to fit, it was a very tight fit, i had to line it up on both sides then i eventually got on top and stamped it home, might damage part of the thread but a quick thread file sorted it
Markus, one centimeter is a lot of mismatch. One or two millimeter mismatch may be forced to fit.
Jacking the car up on one side will not make it fit - if it does, I'll be very worried.
Either it's the wrong strut bar or the car has had a collision and deformed that much.
Nonsense!pac1982 wrote:front struts are only really worth fitting if you drive hard, it may not fit due to you having the wrong version, I'm fairly sure they differ for 6 pot and 4 pot cars and you could have even been sold one for a totally different car
I've only seen two E30s that I've tested a Sparco strut brace I have without any problems.
For example... Years ago somebody local had a 325i Touring, fitted a strut brace on it.
6 months later, another guy bought a 318is and they tried the strut brace off the Touring to see if it fitted and was fine apart from a small bit of prising but nothing out of the ordinary
He was suppose to get a strut brace but never did. A year later or so, the Touring was being sold and he took the strutbrace off it to fit on the iS as he never got round to getting on.
The struts were now over an inch off what they were the previous time they were fitted.
Car wasn't crashed or anything, just driven a little hard and both cars were lowered a little.
Granted, it was driven hard but if hard driving distorts the shell over an inch in the space of a year, I'd give a fair guess 20 years of constant flexing even if not as much force doesn't help either
Anyways, if you comtemplating about fitting a strut brace if you should do it or not. Chances are, you don't drive like miss daisy anyway.
Every E30 should have them. It's probably the weakest part of the shell in terms of flex.
As Kos, says... It's probably bent even if it was never damaged or anything but by just wear and tear.
Justin325i
So how would you get this sorted??Dave_M3 wrote:Nonsense!pac1982 wrote:front struts are only really worth fitting if you drive hard, it may not fit due to you having the wrong version, I'm fairly sure they differ for 6 pot and 4 pot cars and you could have even been sold one for a totally different car
'93 E30 325i Calypso Cab
If your strut towers had flexed as much as an inch or even 1cm you would have camber issues and uneven tyre wear.
A 4 wheel alignment will show up any issues.
- hillbilly30
Is it the strut brace at fault? Cheap one from China? If you measure between your strut mounts (centre to centre) I, and I'm sure others would be happy to nip out to the car and compare!
- hillbilly30
From centre to centre of BMW stamp on strut top cover I've got 995mm if that helps
potentially could be quite interesting to see the variation in these measurements. il do mine when its back from the MOT todayhillbilly30 wrote:From centre to centre of BMW stamp on strut top cover I've got 995mm if that helps
Justin325i
Can the towers be brought back into alignment?
- hillbilly30
If anyone finds much difference in this measurement please don't post it, as far as I'm aware my car is not bent! I like it that way!Rich320I wrote:potentially could be quite interesting to see the variation in these measurements. il do mine when its back from the MOT todayhillbilly30 wrote:From centre to centre of BMW stamp on strut top cover I've got 995mm if that helps
Haha.
I'll measure mine tomorrow. I know two of them are perfectly straight. The iS was a few millimeters collapsed inwards.
Not sure about my other two shells so will be interesting. I'll be pointing the finger at others to blame if I end up scrapping my E30s upon revealing they are all bent however
Best to measure it from one of the bolt holes to the opposite one as the top mount covers could give abit of variation.
- Brianmoooore
- hillbilly30
Well that makes me about 5mm narrow give or take! Not far out but enough to make a strut brace a pig to fit! I have one in the post so I guessing will find out v soon!!Brianmoooore wrote:http://www.300mm.de/download/rahmen.jpg
what brace you getting???hillbilly30 wrote:Well that makes me about 5mm narrow give or take! Not far out but enough to make a strut brace a pig to fit! I have one in the post so I guessing will find out v soon!!Brianmoooore wrote:http://www.300mm.de/download/rahmen.jpg
- hillbilly30
Not sure, it's off a guy on here! Was fitter to an "is" as mine so it might even fit.
Black_Potato
- Contact:
If you arnt already....
Only loop the brace lightly over the thread and just put the nut on the top a couple of turns then fit the other side. Dont tighten one side al the way down 1st if you see what I mean as it will only make it harder.
FWIW I've moved one from a 318i to a 320i without a problem.
My 2p... They are not worth the weight gain on a saloon car or a race car in most scenarios, maybe in cab I can see the point but beyond that I would look to control arm bushes, ARB & Mounts, top mounts, dampers ( or a roll cage in a race car) etc.. as all ways of fixing alignment and roll issues.
3x S14 Rightness....
i fitted one to my is, an RPM , it was a tight fit and didnt quite fit if the car was sat on the floor, had to jack the front end up letting both wheels hang and take the stress of the turrets to get it on
it made a lovely much for the better difference to the car, more solid and better cornering
Justin325i
So can a flexed chassis be brought back into correct alignment?
- Brianmoooore
That's what 10 tonne body jacks are for!Justin325i wrote:So can a flexed chassis be brought back into correct alignment?
when ive ever fitted a solid strut brace (they are the only ones worth fitting imho) ive had to prise it onto one of the turrents using a long screwdriver to lever it.
