For some reason, I always have this STOP working on any e30 I get...the windows stop working with the door open (the window switches aren't illuminated either).
I don't THINK it's a door shut sensor thing - is there a fuse that blows? If so - which one?
I think I am being really dumb...
Thanks!
Gus
Windows not working with door open
JungleGus
Fuse is 28. Shared with the lighter and electric aerial.
TPS
Common Problem that
JungleGus
The aerial and cigarette lighter seem OK - will check it out. Thanks!
bdx
Check door pin switch. It's has double contacts.
gnrsoul
I had same problem and was this, the door pin switch was corroded cleaned it up then all was goodbdx wrote:Check door pin switch. It's has double contacts.
JungleGus
Dirty door pin switches - cleaned and fixed!
