e34 ujs
tweeks
in need of 2 e34 ujs for rack conversion. are both the ujs on the e34 the same? or do you have to get one from two separate cars? cheers.
Dave_M3
There's only one in them so need two from two different E34s
GB69
I got 1 from the my e34 I was breaking, then bought another off ebay. Which bar to use to link the 2 together?
ross2009
danthe sells the splined bars on ebay pm him im sure hell have some
tweeks
there was none on ebay when i looked. there is a pair on there now. got mine from this site http://www.schmiedmann.co.uk/5_series/E ... 6.htm#3803
quite a handy site. can buy new or used too.
DHFiS
You can use one of these
http://www.ebay.co.uk/itm/VAUXHALL-CORS ... 3a85f29e16
with E30 ujs
http://www.e30zone.net/e30zonewiki/inde ... ng_Linkage
with E30 ujs
wellard
I only used one e34 uj on my conversion in conjunction with one of danthe's steering shafts.if you remove the top and bottom uj sections from the e30 steering shaft and join them together then you can use that at the top and the e34 one at the bottom, saves buying two e34 joints.
