problems after m42 swap, help please!
baggimodo
Post Sat Sep 28, 2013 2:52 pm
After I've swapped in an m42 I've now not got any temp reading or rev counter. I didn't realise about the positive to earth problem and it melted the wiring in the loom.
I've tested the wiring to the temp gauge by earthing it and I get movement on the guage so don't suspect terminal damage here but could I have damaged the rev counter wiring? Does anyone know which wire feeds information to the rev Counter from the en
gine bay? And the corresponding wire to look for ecu side?
Post Sat Sep 28, 2013 3:01 pm
It would help to know what model of car you have converted from!
There are wiring diagrams here:
http://www.e30zone.net/e30zonewiki/inde ... g_Diagrams
baggimodo
Post Sat Sep 28, 2013 3:34 pm
Oops! 318I m40 sorry!
Post Sat Sep 28, 2013 4:27 pm
What did the M42 come from?
baggimodo
Post Sat Sep 28, 2013 5:32 pm
E30 off zimmer Matt
Post Sat Sep 28, 2013 5:41 pm
If earthing the temp gauge gets it to move (it should fully deflect), then it should work OK with the sender; if not, measure the resistance of the sender with the engine cold then hot, to verify that the sender is working.
Melted wiring looms can damage any part of it, so you need to carefully check each of the affected wires, and trace them back to where they go - use a multimeter to check their continuity.
Post Sat Sep 28, 2013 6:29 pm
baggimodo wrote:E30 off zimmer Matt
That's my theory gone then! BMW engines from other models can have a sensor that's incompatible with the E30 gauge, so need to be fitted with an E30 sensor.
Follow what Speedtouch says for the temp gauge.
Tacho wire is a plain black one from a dedicated output on the ECU to the instrument cluster, passing through the C101 on the way.
