No spark no fuel !HELP !!!!!
JAFF
Post Wed Sep 18, 2013 8:45 pm
Evening to all ,
majorly frustrating problem ...
on my way to work the other morning i pulled over to let a friend out the car and the car died all of a sudden like it had stalled ,failing attempts turning it over and jumping it didnt work .
iv now got it home but i have no fuel at the fuel rail and no spark at the plugs ,iv looked and changed the crank sensor with no further luck
now it dose have what i believe to be a factory fit alarm/immobilizer it is in the off position and has been since i brought it
like i said iv checked for spark and fuel so dose any one have any ideas ????
this is completely out of the blue
The alarm horn has a lock where by the key switches on or off the alarm and its in the off position
its a 2.8 m20 (conversion i did around 10k ago and hasnt missed a beat )
:cry:
JAFF
the alarm module only has APS 1988 wrote on it i cant see any more than that
DarrenMe30
Post Wed Sep 18, 2013 9:03 pm
Hi,
See the answer to my alarm immobiliser query earlier today, worth a try!
Post Wed Sep 18, 2013 9:14 pm
First test is to connect a 12 volt bulb between the + terminal of the ignition coil and earth, and see if it lights with the ignition on.
JAFF
Post Wed Sep 18, 2013 9:19 pm
thank you brian iv just been reading the wiki pages and i have tryed the crank sensor will give that a go aswell tho
darren ill look it up now ta
Post Wed Sep 18, 2013 9:22 pm
Do not start randomly testing/changing parts. That is the route to starting with one fault and ending up with ten.
Check for power on the coil +, as above.
JAFF
thank you brian will do
JAFF
Post Thu Sep 19, 2013 7:32 pm
brian there is power to the coil , the fuel pump kicks in when its bridged the dme relay clicks when the ignition is switched on ,
i have tryed to check the crank position sensor but im not really sure how to
is there anything else i should look at
Post Thu Sep 19, 2013 7:55 pm
Does the fuel pump run when you crank the engine?
Test the CPS by unplugging it under the diagnostic socket, and measure the resistance between the two terminals of the plug nearest where the cable exits.
Should be about 540 ohms, and remain stable when the wire to the sensor is moved anywhere along its length. Note that an incorrect reading confirms a faulty CPS, but a correct reading does not confirm its good, and that wriggling the wire to the sensor may turn a working sensor into a faulty one if the cable is already damaged.
JAFF
Post Thu Sep 19, 2013 8:08 pm
there is no fuel pump or spark when i crank the engine ,the cps socket has 3 pins located inside the connector and iv tryed others with no luck on different combinations i get a flicker of a reading but nothing that relates to 540 ohms
i can only think it is the cps then ?
Post Fri Sep 20, 2013 10:04 am
If you're sure there's no reading that is approximately correct across the CPS plug, then it's faulty.
JAFF
Post Sun Sep 22, 2013 4:53 pm
Brand new CPA fitted still no joy
