Can someone confirm or deny this please.
I do not need to connect the small white double green wire plug from the OBC harness to the car harness unless i am using the Code function on the OBC.
Whats the twin red/white trace in the OBC loom for, as i forgot to take a piccy of the connection before i removed it from the donor car.
I am not using/installing the Aux horn with the OBC.
OBC Retrofitt
kam-325i
oze30
try this!
http://www.e30zone.co.uk/modules.php?na ... troobc.htm
Did it take long to fit> I', looking at doing this to mine.. If I keep it!
kam-325i
the article guide has no mention of a plug with a twin red/white trace wire.
kam-325i
These are the connectors in question.
The top one has two Red/White Trace (on one connection). Whats this for ?
The bottom one is for the CODE fuction/Immobiliser ? Can i leave this dissconnected ?
M5pilot
Your so going to regret fitting this when you have a bigger engine as all it will ever say is.........18 mpg to you.
Simon
The red/white connector, would plug into the junction box above the glovebox, you do not need to plug in the wire for the code function, the OBC will work fine without it.
kam-325i
Last Question.
The coding plug in the back of the OBC, does it need to be changed for different engines ?
The OBC was original fitted into a 320i, no going into a 325i.
Simon
Fancy a swop?kam-325i wrote:Last Question.
They do need to be changed for different engine sizes, but it's not like the OBC is very accurate anyway!
kam-325i
You want the coding plug for an M20B20 ?
If you want to swap for a M20B25 one.....
(Coding plug for the OBC, Not the dashborad)
Simon
Yes, I have a 2.5 coding plug in my 2.0, I shall have a look tomorrow to see if I can remove it easily enough and shall let you know.
kam-325i
OK, will do.
The plug is VERY Tight.
Mine has 4 4 Typ, 1385939, 9.89 on the back
kam-325i
Just to let you know Si, i have checked the part number on the plug (1385939) and it is for a 320i, the coding plug i need should have 1385941 on the back.
Simon
Cheers, I'll check it out today, and get back to you
