Dead Electrics!
MikeRothwell
Post Sun Feb 13, 2005 12:50 pm
Hello All,
Anyone know why 'all' of the electrics should die after draining the battery?
Like a fool I left the sidelights on (for 36 hrs!) Battery dead as a dodo of course.
Swopped it with another which I know is a good un, but everything is still dead. No interior light, dash warning lights or anything. Even the LED on the Cobra alarm is dead.
I've checked the fuses (all fine)
Thought it could be the Alarm, but that normally wouldn't stop the radio, interior lights, sidelights, etc, so not sure if it is something even more fundamental.
She's an 87 325i if that makes any difference.
Cheers in advance for any help.
Mike :(
BIGMRLEE
Post Sun Feb 13, 2005 1:36 pm
sounds like either the battery isnt any good try another or try jump starting it from another car, if you still have no joy get back to me and i will check on mine to see if there is anything else that could be wrong.
Post Sun Feb 13, 2005 2:18 pm
No fusible links on an E30 that I know of, so either your replacement battery is flat, or the battery terminals aren't making contact.
The only things that you may have upset should be the radio and engine ECU. Might run a bit lumpy for a 100 miles untill it sorts itself out.
