Door card lifting
polsta
Sat Sep 07, 2013 12:24 pm
Has anyone ever came up with a fix/solution to rear door cards (2 door) lifting away along the top edge ?
**BANNED**
Sat Sep 07, 2013 12:37 pm
Assuming the construction is similar to front door cards,I found that steaming would allow the fibre board to be re-shaped.
Send your 'er indoors out shopping,then boil a large pan full of water,hold the cards in the steam and re-shape as the thing becomes pliable.
Replace all kitchen utensils exactly where you found them,after removing oily paw marks.
Youth is wasted on the young.
polsta
Sat Sep 07, 2013 2:49 pm
ok cool il give it a go, is there a better way to steam rather than a big pan ? (sounds like it would take forever)
its rear cards not front, got 2 pairs to try fix, i did source a nice pair to replace my ones, now they seem to have gone the same way- the "bend" along the top just needs to be bent back in to shape/sharper bend
**BANNED**
Sat Sep 07, 2013 2:50 pm
diable wrote:I did the fronts on my cab and as daimlerman said steam them, I also placed mine on MDF and used a couple of ratchet straps to hold the top edge in place whilst they dried.
It's only the driver's door(o/s) that seems to suffer on cabbies..3 or 4 years on and my cabbie's door card is getting to the point off needing doing again.
Vital part,I think,is defending your position regarding the use of 'er kitchen!
**BANNED**
Sat Sep 07, 2013 2:56 pm
polsta wrote:ok cool il give it a go, is there a better way to steam rather than a big pan ? (sounds like it would take forever)
Matter of ten or twenty minutes,are you a man or a mouse? winkeye
adit
Sat Sep 07, 2013 5:50 pm
yes! :
:teehee:
or, if you can't fit that in your boot, one of these Carl:
http://www.ebay.co.uk/itm/Electric-Port ... 257546b113
[quote="bss325i"]
TPS
Sat Sep 07, 2013 5:58 pm
You can fit one of them in my boot, when I remove all the scrap from it!!
Gavla
Sat Sep 07, 2013 6:01 pm
polsta wrote:ok cool il give it a go, is there a better way to steam rather than a big pan?
Soak them in a hot bath...reshape them making sure they dry in that shape and then use a liquid hardener (same stuff for fibre glass).
polsta
Sat Sep 07, 2013 6:25 pm
Interesting, have you tried and tested that gav ?
Gavla
Sat Sep 07, 2013 9:14 pm
I did it with some front ones. As soon as they get wet they become very flexible. The ones I had were quite warped and the top "curved" part was splitting. Once wet I laid them flat on the bathroom floor and put some heavy items on top to get rid if the warping. Then once dry I put the hardener around the "curved" top part to stop the splitting and keep the shape.
I am assuming the same would happen to rear cards if you use hot / boiling water and the hardener will "rienforce" the shape...?
billgatese30
Mon Sep 09, 2013 11:48 pm
Thread moved from E30 Chat to E30 Technical Help. Your thread should receive the correct responses when posted in the correct forum area. Please try and think about the subject of your thread before you post and consider if you are posting in the correct section.
Regards,
E30Zone Team.
