HIDs problem
grumpyoldman
Fitted my hids and dont work or one side or the other might work ?
BenHar
Have you been drinking?
I have, but I still can't work out what you are asking. Try giving a bit more information.
Ben
Ben
grumpyoldman
Fitted my new HIDS kit and at first worked fine 5 mins later both sides not working then 5 mins later one side or the other would light up or none at all ?
BenHar
Check all the connections including the earth in the front corner of the engine bay.
Ben
Ben
Sanchez
What year is the car?
Theres a black connector in the inner wing behind the passenger side light.
This needs disconnection on some e30 models fo fit HID's properly.
Can remember the name if it but it could be a fault for you.
