Upgrading 323i throttle body to bigger (i.e. 325i) spec Q?
M6luvva
I just realised my throttle body for the 323i is MUCH smaller than it's counterpart for the 325i. Could I reasonably expect any power gainby replacing my stock unit with the larger 325i one?
I doubt it.
When did you last check / adjust your ignition timing ? Far more power to be gained by doing this PROPERLY , and it is FREE !
