timing tensioner diagnosed fatal.
316injection
So I took my E30 316i M40 for an annual TLC session. Was running fine, floating like a butterfly, as it always has for the many years I've had it.
Mechanic hears a rattle, inspects, and shows me a bolt hanging loose inside the timing belt casing at front of engine. I agree to belt and tensioner change and a few other things.
Next day mechanic calls and says the thread for the bolt is so worn down, a new bolt cant be fitted, meaning timing belt system is unrepairable. I'm told the options are rebuild engine or buy new engine = muchos cash.
So I'm pretty gutted right now - and confused. The diagnosis makes sense, and I was aware of the on off rattle. However, the mechanic's hint at a 200 quid scrap price after diagnosis has planted "am I being conned...?" thoughts.
So I'm reaching out to you comrades on the forum for opinions and suggestions for workarounds.
Cheers!
Cheers!
kam-325i
is it the thread on the bolt or the thread for the bolt in the block....
kam-325i
Helicoil repair.........
316injection
helicoil, for the block? any testimonials from users as to effectiveness in block, timing chain environment?
Grrrmachine
- E30 Zone Wiki / Team Member
Don't use helicoil, use a threaded insert like a TimeSert. Much stronger than a Helicoil.
kam-325i
Err......yeah, i would second that actually......Grrrmachine wrote:Don't use helicoil, use a threaded insert like a TimeSert. Much stronger than a Helicoil.
maggspower
- Turbo Farmer Tractor Driver
Both Time-Serts and Helicoils will work fine for the job as long as they are fitted correctly.
I would however suggest looking for another mechanic. Fitterz should not be looking after older motors, and offering you scrap value
Rescue you car and take it to someone who knows what they are doing.
Contact: theengineshedonline@gmail.com
Or try a tap and die set to clean out the thread.
Failing that, it could probably be drilled out to a larger size and then tap & die'd to give it a thread.
Another possibility is to weld a nut of the right size over the hole in the block, assuming there's room...
I suppose a temporary 'get you home' fix would be to use JB Weld, Araldite or Chemical Metal to bond the bolt in - that would at least get it mobile again, so you could take it for a proper repair.
scjimbo
Depending on what size the bolt is thats come out, (i.e M6) The od of the thread across the tops of the threads is 6mm. If the bolt is actually slopping around in the hole it is probably worn to about 6.2-6.5 mm. The tapping drill size of a 8mm thread is 6.8mm. If you get a nice clean GOOD QUALITY tap from your local engineering suppliers and go very steady, It will probably cut the excess out of the way without re-drilling the hole anyway. However if you are new to the metal cutting game it may be worth popping to a local friendly engineer who will know how to handle a tap correctly. The last thing you want to do is snap the tap off in the hole. A tap is much much harder than a drill.
316injection
The mechanic has fantastic reputation on this forum hence I took it to him
Is there a point at which Time Sert HeliCoil would not be effective eg could the thread be too far gone?
scjimbo
A helicoil requires a new much bigger thread to be cut. What size is the thread that's stripped mate?
gooner1
- Out humping Reindeer
Who be that then?316injection wrote:The mechanic has fantastic reputation on this forum hence I took it to him
316injection
ill see how this plays out, and if im left unsatisfied i'll consider blowing the whistle.gooner1 wrote:Who be that then?316injection wrote:The mechanic has fantastic reputation on this forum hence I took it to him
re size of thread - i dont know. whatever size the tensioner bolt is in an M40 timing belt set up... any one know?
wellard
Which bolt is 'hanging out?'
Iirc the tensioner is on a 10mm stud secured by a 15mm nut and the two guide pullies are on 8mm bolts.
scjimbo
Ok well depending on which one it is. A 10mm stud would need a 14mm ish od helicoil in it. That means about an 11.8 tapping drill. (Helicoils use their own odd thread sizings for their inserts). If its one of the 8mm studs I believe it goes out to about 12mm which is a 10.2mm tapping drill.
The good news for you, is you can fairly easily take a 10mm worn hole out to 12mm with some care. The tapping drill size for m12 is 10.2mm.
Not being au fait with your engine though, you will have to take some advice from someone on here more learned than me, as to whether the tensioner can be modified to take a 12mm stud and nut.
My advice though, is if you are going to do this yourself, I would take the radiator out so you can get yourself square to the hole you are tapping.
Hth
Hth
gooner1
http://www.realoem.com/bmw/showparts.do ... g=11&fg=10
Not having a pop at your mechanic, he may well have good
reasons for suggesting another lump, or a rebuild.
Can you get him/her to point out which bolt, from the above
link, is causing problems due to the block thread being knackered?
316injection
gooner1 wrote:http://www.realoem.com/bmw/showparts.do ... g=11&fg=10
Thanks Gooner, from my memory it looks like part no2 the shaft seal was loose in the casing. When I got the call next day mechanic said the thread was worn for the tensioner bolt. I spoke to them again a few days ago and now Ive been told the bolt has snapped off in the block. I have also been told "the part" they need to fix it is not available. Its a different story every time I call.
And this is one of most reputable mechanics on this website
Well, that doesn't make sense; if the thread was worn, why would the bolt then snap off in the block, when surely it would either waggle about or pull out?
Sounds like they are trying to cover a f***up
TPS
+1DanThe wrote:Sounds like they are trying to cover a f***up
gooner1
316injection wrote:
And this is one of most reputable mechanics on this website![]()
There is no such Animal here.
316injection
now that could be a possibility. why would I be given a diff explanation each time:
explanation 1. worn tensioner thread in block, get new engine
explanation 2. cant get the part, get new engine
explanation 3. bolt snapped off, get new engine
thats 3 totally different explanations. doesnt add up does it....?
How many miles has the engine covered, and did it use oil or smoke at all?
If the rest of the engine is in good condition, then it's worth having a go at repairing it - probably alot easier and cheaper than fitting a replacement engine.
maxfield
+ 2TPS wrote:+1DanThe wrote:Sounds like they are trying to cover a f***up
I can't see there being an issue with the threads, unless they've fucked the threads up themselves. It's a bolt that only gets undone and tightened back up 2-3 times in its life and it isn't open to the elements.
bmw9818
unless timing was set wrong resulting in new donkey
316injection
basically they are whatever the fault - worn thread / snapped bolt/ part not available - they say the ONLY solution is new engine.
Sounds like b*ll*cks to me...
316injection
yeah, and they wont let the car out of the garage, saying they will only allopw it to leave on a trailer or when its roadworthy. like i said, one of the most highly regarded mechanics on this site!Speedtouch wrote:Sounds like b*ll*cks to me...
bodger
tell them its your f*cking car you will do what you like with it, name and shame i say316injection wrote:yeah, and they wont let the car out of the garage, saying they will only allopw it to leave on a trailer or when its roadworthy. like i said, one of the most highly regarded mechanics on this site!Speedtouch wrote:Sounds like b*ll*cks to me...
maggspower
gooner1
316injection,
have you told the reputable mechanic that you have posted all this
on here?
Would be interesting to see his/hers/their response.
If the engine is fooked, how else would it leave the garage other than
" on a trailer" ?
on here?
" on a trailer" ?
scallyally
Let's hear this "mystery mechanics" response, you may have a valid reason for suggesting a replacement engine.
Come on, what's your side of the story? We've got a fellow zoner's car laid up ( held to ransome)? Man up! Or be named and shamed.
