Power Steering noisy
trackdemon
Post Sat Aug 17, 2013 5:07 pm
I've just got my 318iS taxed and back on the road after a bit of time with it SORN'd, and after a precautionary oil change and replacing an exhaust hanger it seems to be running pretty well except for nasty sounds from the power steering when applying lock at idle. Any ideas why it's making this noise, and how to fix it? Is the steering pump on its way out?
adamt93
Post Mon Sep 02, 2013 9:00 pm
Well it would be loads as it is only on idle it probley ain't nothing just the power steering ain't turning fast enuff so it just makes a little noice
trackdemon
Post Mon Sep 02, 2013 9:33 pm
Ha, thought this post was dead! It seems fine when driving along, it's only at idle & only really when applying large amounts of lock. Strange...
trackdemon
Post Mon Sep 02, 2013 9:38 pm
Yes checked PS fluid level, looks fine
Rob_farmer
Post Thu Nov 21, 2013 7:59 pm
I had same problem, noisy steering wheel when stationary - fluid level was too low.
I`m driving E30, 1989, 325i, 4 door. Restoring 1990, 4 door.
Post Thu Nov 21, 2013 10:01 pm
What sort of nasty noise? It's normal for the pump to complain a little at full lock, since the fluid pressure increases greatly when it hits the stops.
Billwill
Post Fri Nov 22, 2013 12:24 pm
What Brian said....the power steering on both my E30s complained when at full lock while at idle...sometimes causes the engine to stall! :?
