handling and wide track
markus_74
Post Sat Aug 17, 2013 3:48 am
hello,
need some info on how wide of the front and rear track influence of the handling?
i plant to use 13mm spacers on front and 15mm spacers on rear, but my friend suggest me to use 10mm on front, does it will increaase the handling if I use wider track on rear?
and does it is still save to use this size?
my wheel is 15 inch wide 8j et25 front and rear is same, tire 205/55/15.
Thank you
Post Sat Aug 17, 2013 9:54 am
If its a prefacelift you might have arch contact on the rear, especially with 15mm spacers, the track is wider on the rear as standard
markus_74
Post Sun Aug 18, 2013 8:36 am
my e30 is 1991 so I think it is facelift
