Bump strip removal
cjdonny
Post Tue Aug 13, 2013 5:05 pm
Thinking about painting mine plus rear is scuffed needs filling
Are they easy to remove/refit
Any pics of is brilliant red with them painted
318 IS
polsta
Post Wed Aug 14, 2013 7:08 am
I did mine donny, remove the rear bumper then pop the clips off from inside I'd the best and sure thing way to not break them , also allows for a good clean behind snd check for rust spots/scabs developing and treat
Painting them looks great / upol from halfords a good plastic filler you then sand once dry, plastic prime then paint- just be careful with scratches once re fitted but look great, try re painting with satin black enamel spray paint for z more durable finish
cjdonny
Post Wed Aug 14, 2013 8:15 am
Cheers for rely
What about the side bump strips, how do you remove them winkeye
318 IS
