Dim Cluster Lights
SAP1
Post Mon Aug 12, 2013 11:27 am
Does anybody know why the lights on the cluster are so dim? I've changed the switch and no difference.
Post Mon Aug 12, 2013 11:40 am
Have you tried rotating it - it also acts as the lamp dimmer!
SAP1
Post Mon Aug 12, 2013 11:50 am
Yeah tried that haha! Still no difference
Post Mon Aug 12, 2013 12:30 pm
Maybe one or more of your backlight bulbs are blown, or on their way out.
It's a fairly easy job to remove the cluster and the bulbs just untwist at the back.
http://www.e30zone.net/e30zonewiki/inde ... eplacement
SAP1
Post Mon Aug 12, 2013 12:47 pm
Changed the bulbs aswell. Could it be the SI board battery?
Post Mon Aug 12, 2013 1:17 pm
Unlikely, but possible. Did you fit bulbs of the correct wattage?
SAP1
Post Mon Aug 12, 2013 1:30 pm
Yep 3w bulbs
Post Mon Aug 12, 2013 2:03 pm
In that case, check the connections to the back are secure, and that you have a good earth.
Do the rest of the instruments and SI lights work OK?
SAP1
Post Mon Aug 12, 2013 2:05 pm
Well sometimes I put the ignition on and get 5 green lights and then sometimes I get 2
Post Mon Aug 12, 2013 2:17 pm
That may well be indicative of duff SI batteries then.
Billwill
Post Wed Aug 14, 2013 2:33 pm
Could be a bad ground on the dimmer switch...try shorting either wire on the dimmer switch to a good clean ground point..these wires go to ground (G100) I think in any case. :wink:
