when the car is coming to a stand still, literally before it stops, theres a springy kind of sound and the brake pedal goes a bit funny, abit stiff and soft again..bouncyish.... hard to explain but can anyone give some sort of advice..
the cars a 325, facelift, with abs....
ive tried changing the relays above the pump, but still the same issue...
ABS issues
DavidgiDavies
The ABS system is actuating because the control unit is seeing one wheel speed dropping to zero before the other three.This generally means there is an abnormality with one of the toothed sensor rings.Remove the road wheels and examine each sensor and toothed wheel in detail.Look for cracked sensor rings or excessive rust build up.
