dogleg guibo
biker50610
Post Tue Jul 30, 2013 8:08 pm
I need to replace the guibo on my dogleg trans, that is in a 85 323i. being state side it is not as easy to get parts and info on cars that where not sold here. so need to know if the guibo from the 325e or 325i will work on mine. if they do might as well get the revshift one thanks
Post Tue Jul 30, 2013 9:09 pm
Part's the same throughout the E30 range, except for the M3.
If there's a vibration damper (heavy metal sleeve) fitted around your existing guibo, this can be left off when fitting the new one, since an improved design no longer requires it.
