What Limited slip diff ??
mini-mad
Post Sat Jul 27, 2013 12:49 am
Right I read the wiki page which was really helpful but I still dunno that will do the job.. My cars a 318i the 4:10 diffs would fit but there hard too get now ? I was thinking would a 318is e36 diff work or what else would ?
Cheers Adam
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Jul 27, 2013 9:36 am
You need a diff from an E30. All later models had different gearboxes that lacked the E30's overdrive gear (less that 1:1 gear ratio). This means that E36 diffs start at about 3.25 - far too low for your 318i.
4.10 is what you need, but you can go one ratio up or down without it hurting performance too much.
Work out why you want an LSD first, and then decide whether it's worth the expense.
AlpineCab
Post Tue Jul 30, 2013 3:25 pm
Theres also the 4.44 which ain't a million miles from the 4.10?
