as above how can one adjust the tension on the rear boot door hinges as i have fitted a tech 2 spoiler/boot to the car and it previously had no spoiler so the tension in the hinges needs to be increased quite a bit to take the weight!
thanks!
boot door hinges/springs how to adjust tension?
Assuming we're talking about a saloon, there are three (?) positions that you can hook the fixed end of the torsion spring into. Should be obvious when you look at it.
madmax1410
its a 2 door coupe hard top i had a look but didnt see anything obvious to adjust it!Brianmoooore wrote:Assuming we're talking about a saloon, there are three (?) positions that you can hook the fixed end of the torsion spring into. Should be obvious when you look at it.
thanks for the info!
Grrrmachine
- E30 Zone Wiki / Team Member
2-door saloon then. You don't want to know what the E30 Coupe looked like...madmax1410 wrote:its a 2 door coupe hard top
madmax1410
alright i had a look and seen there was 2 positions to adjust the tension on both of the cars! any way it was easy to do and now no more worrying about the boot door closing on my head!Brianmoooore wrote:Assuming we're talking about a saloon, there are three (?) positions that you can hook the fixed end of the torsion spring into. Should be obvious when you look at it.
i also noticed the donor's hinges have much more tension but were in the same position as the other car so there must be another difference some where?
