Hi could anyone out there tell me if coupe springs will fit a touring model or will it have to be a special kit?
Touring Springs
kam-325i
Springs for the tourer are stiffer, due to extra weight in the rear end.
Rich25i
Cheers thought so my mate kept on and on so thought i would check.
kam-325i
They will physically fit, but the back end will be slighty lower, and might bounce off the bump stops a bit more.
Simon
Don't do it!!
I've got a saloon kit on my touring, and the ride is awful, when there's a person in the back, it get's un-bearable, stick to touring specific stuff, or go for convertible springs, the cab is heavier over the rear end than a touring.
M5pilot
Do NOT fit saloon springs to a Touring, you will regret it.
The only specific kit thats worth fitting is the H&R spring kit or just fit the H&R cab kit.
oze30
so basically, if I wanted to replace the springs on my touring... I'd go for Cab springs??
Simon
Or touring springs..oze30 wrote:so basically, if I wanted to replace the springs on my touring... I'd go for Cab springs??
